The auger bit on this type has a point on the end, one cutting spur and a single spiral for rapid chip clearance. The single spur is easy to sharpen and the bits cut evenly and fast, even in the hardest of timbers.
Harima
Japanese Pattern Mortice Bits Only
| Shank Diameter | 2026-08-03 00:00:00 +0100 |
| Size | 2026-02-01 00:00:00 +0000 |
| Metric or Imperial | Imperial |
| Bit Size | 2026-02-01 00:00:00 +0000 |
| Web Attribute Set | Hollow Square Mortice Chisels & Bits |
| EAN Barcode | 4560272502047 |
