Hermes BW 110 Abrasive Belts 150 x 2,260mm
From £11.58 £9.65
  4. Empty Star
5 Reviews
  • Aluminium oxide abrasive on E-weight paper backing
  • Semi-open coating, antistatic resin bonded, reduces clogging
  • Economical sanding for excellent results on all types of wood
The aluminium oxide abrasive on an E-weight paper backing has a semi-open structure with antistatic properties to reduce clogging. BW110 is especially suited to sanding hardwoods and is suitable for use on metal. It has a good stock removal rate even with low sanding pressure. BW110 is an excellent multi-purpose abrasive for use with powered sanders.
To fit Jet OES-80 CS oscillating edge sander and the Axminster AT 6X90 oscillating belt sander.
3.00 5
