To fit Axminster Industrial Series 6 x 108 Belt Sander. The polyester/cotton back combined with the resin bonded aluminium oxide grain mix produces a high stock removal with course grits, plus a consistent surface quality with fine grits. Smooth running and long lasting, perfect for abrading metals and sanding seasoned woods.
Hermes
Hermes RB 377 YX Abrasive Belts 150 x 2,770mm
| Abrasive Material | Aluminium Oxide |
| Abrasive Type | RB 377 YX |
| Abrasive Belt Length | 2,770 mm |
| Abrasive Belt Width | 150 mm |
| Abrasive Backing | Cloth |
| Pack Quantity | 1 |
| Abrasive Grit | 80 |
| Web Attribute Set | Abrasive Belts |
| EAN Barcode | 4050806913741 |
