A range of 305mm diameter hook and loop backed sanding discs suitable for the Axminster Trade SS-12VS, Jet JDS-12 and previous model Axminster DS12VEL disc sanders.
The aluminium oxide abrasive on an E-weight paper backing has a semi-open structure with antistatic properties to reduce clogging. BW115 is especially suited to sanding hardwoods and is suitable for use on metal. It has a good stock removal rate even with low sanding pressure. BW115 is an excellent multi-purpose abrasive for use with powered sanders.
Available in a variety of grits. Sold in singles.
Abrasive Type VC 153 VEL
Abrasive Disc Diameter 305 mm
Size 305mm
Pack Quantity 1
Abrasive Grit 120
EAN Barcode 4047915787530
