Hermes VC 153 VEL Abrasive Discs 25mm, 50mm & 75mm
- Hook and loop backed aluminium oxide abrasive for quick changes
- Strong E-weight paper backing with good edge stability
- For wood, metal, lacquers, paint; supplied in packs of 10
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price £69.97 £58.31 was £89.98 £74.98 Save £20.01 £16.67
Hermes VC153 Abrasive discs with hook and loop fixing, available in a full range of grits. Manual sanding/grinding of wood, filler, lacquer, primer and metal materials using random orbital, angle grinders and hook and loop orbital sanders. They have many applications and are particularly suited to sanding and finishing turned bowls. Available in 25mm (1"), 50mm (2") and 75mm (3") diameters in packs of 10 discs.
Abrasive Backing | Paper and Hook and loop |
Abrasive Type | VC 153 VEL |
