Hermes BW114 VEL Abrasive Disc 200mm (Pkt 10)
- Aluminium oxide abrasive with strong F-paper backing
- Antistatic properties and open grain coating to reduce clogging
- Perfect for sanding soft woods
- Suitable for applications with high grinding pressure
- 200mm diameter
Hermes BW114 VEL Abrasive Disc 200mm (Pkt 10) 120 GritFrom £17.48 £14.57
These Hermes abrasive discs will shorten your machining times and are fitted with a hook and loop fixing for quick and easy disc changing. The aluminium oxide, velour-backed discs have antistatic properties and have an open grain coating to reduce clogging of sanding dust. They are easy to handle, as a result of the strong F-paper backing. BW114 is especially suited to sanding soft woods and for applications with high grinding pressure.
These discs are suitable to fit the Axminster Workshop AW200BDS Belt & Disc Sander - 230V.
Available in three different grits. Contains 10 x 200mm discs.
Abrasive Backing | Hook and loop |
Abrasive Disc Diameter | 200 mm |
Abrasive Type | BW 114 |
Pack Quantity | 10 |
