Hermes is one of the UK's leading abrasive suppliers and they have designed a special multi-hole disc with a high quality abrasive. Unlike other 6 and 8 hole discs, when used with extraction, the multi-hole perforation of the whole disc ensures that the extraction airflow can act over the entire area of the abrasive. As a result there is no build-up on the abrasive grain, thus giving a much higher level of performance with a swirl-free finish. There is no need to worry how many extraction holes your sander has and lining them up as this can be used on all 150mm (6") sanders saving time and cost. The abrasive will give high performance and quality with high stock removal. It is made from VC154 aluminium oxide, resin bonded with a longlife coating and put onto a special flexible tear-proof paper backing, making it suitable for all finishing. Available in packs of a selected grits or a mixed pack of 10. The pack of 10 mixed contains 2 each of 80g, 120g, 180g, 240g & 320g. The pack of 50 mixed contains 10 each of 80g, 120g, 150g, 180g & 240g.
