Hermes RB 377 YX Abrasive Belts 50 x 785mm
- Universal belts for sharpening and grinding
- High stock removal rates in the coarse grit range
- Consistent surface quality in the fine grit range
- Polyester/cotton cloth backed aluminium oxide abrasive
Cloth backed belts in a choice of grits. The polyester/cotton back combined with the resin bonded aluminium oxide grain mix produces a high stock removal with coarse grits, plus a consistent surface quality with finer grits. Smooth running and long lasting, RB 377 YX abrasive is perfect for abrading metals.
Abrasive Backing | Cloth |
Abrasive Belt Length | 785 mm |
Abrasive Belt Width | 50 mm |
Abrasive Type | RB 377 YX |
