Hermes VC 152 Decorator's Mate Abrasive 115mm x 10m
- Aluminum oxide on strong paper backing, high stock removal rate
- Open coated, low loading characteristics, less clogging, longer life
- Use for rubbing down paintwork, preparing bare wood etc
Open face and free cutting the VC152 abrasive is the perfect partner for painting and decorating preparation. Staying sharp and clean for longer when sanding painted surfaces means that you get the job done quicker with less paper. You can cut 230mm lengths for 1/2 sheet sanders. Supplied in convenient 10 metre rolls you can take off as much or little as you want from the centre and keep the rest neat and tidy to the last strip.
Abrasive Backing | Paper |
Abrasive Roll Length | 10 m |
Abrasive Roll Width | 115 mm |
Abrasive Type | VC 152 |
