Hermes WS Flex 16 Wet & Dry Abrasive Sheets (Pkt 10)
From £11.68 £9.73
21 Reviews
  • Waterproof silicon carbide abrasive, resin bonded on latex paper
  • Popular choice for sanding, varnish, primer, lacquer and composites
  • Hones edge tools when mounted flat and lubricated with water
Hermes WSFLEX 16 waterproof silicon carbide resin bonded paper, more commonly known as wet & dry is used primarily for car body work. Finer grades can be successfully used for final preparation and between coats of varnish/paints and is pre-eminent in achieving a superb result when oil polishing. It is often used on top of a solid flat surface to sharpen edge tools, the addition of a little water lubricates and prevents the paper from slipping. Available in a choice of 11 grits, 180-2500G. Size 280 x 230mm
The mixed pack contains the following: 240g x 2, 400g x 1, 600g x 2, 800g x 1, 1200g x 1, 1500g x 1, 2000g x 1 and 2500g x 1.
5.00 21
