The Hultafors 108 Mini Wrecking Bar can be used to pull small nails, strips of wood, or open cans. It has three different functions for pulling out nails and the thin contact surfaces make it easy to use in narrow spaces. Length: 190mm (7.1/2").Weight: 77g.
Hultafors
Hultafors 108 Mini Wrecking Bar 190mm (7.5")
| Web Attribute Set | Wrecking & Pry Bars |
| EAN Barcode | 7391408270212 |
