Hultafors HVK Craftman's Knife Enhanced Grip
- Enhanced friction grip
- 2.5mm carbon steel blade, 58–60 HRC; blade length: 93mm
- Handle is super-durable PP plastic, fitted with a Santoprene friction grip
- Total length: 208mm
This Hultafors Craftsman's Knife has an enhanced friction grip. It has been developed and adapted to the needs of craftsmen and features a unique function for attaching the holster around a button on work clothes so that it does not come loose whilst still being easy to remove. The blade is made from 2.5 mm carbon steel that has been hardened to 58–60 HRC. The cutting edge has been sharpened in several stages, with a final honing on a leather strop. The handle is made from super-durable PP plastic and fitted with a Santoprene friction grip. Fits in the same holster as the HVK model and its double holster. Blade length: 93mm. Total length: 208mm.
EAN Barcode | 7317843802115 |
- Standard Delivery* - £1.99
