i2R Vacuum Hold‐Down Kit
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
Please check Click & Collect in-store stock for availability.
- Work holding without clamps
- Secure material to CNC Router bed
- Comprehensive vacuum kit
i2R Optional 6W Laser UpgradeSpecial Price £1,007.98 £839.98 was £1,119.98 £933.32 Save £112.00 £93.33
The i2R Vacuum Hold Down Kit is a revolutionary piece of kit that can effortlessly secure your material to the bed of your CNC Router.
The kit contains 5 connected compact Vacuum Pods, which are made of phenolic resin and each have their own vacuum seal. You can use a single pod for work holding a small piece or lay out all 5 pods to hold a larger project. The pods can be mounted on the integrated spoil board or directly onto the aluminium table. The kit includes screws and T-nuts in both lengths for this. Also included in the it: on/off valve, vacuum pump, hose, air fitting.
Please note: a compressor is required to operate the Hold Down Kit. Requires a minimum of 1.5CFM of compressed air at 90PSI.
EAN Barcode | 5052511133659 |
Overall L x W x H | 400 mm x 300 mm x 25 mm |
Plug Fitted | UK 3 pin plug |
