Ice Bear
  • King Japanese Waterstone - Medium 1,200g King Japanese Waterstone - Medium 1,200g
  • Ice Bear 5 Piece Japanese Oire Nomi Special Alloy Chisel Set Ice Bear 5 Piece Japanese Oire Nomi Special Alloy Chisel Set
  • Japanese Kiridashi Marking Knife Japanese Kiridashi Marking Knife
    £13.88 - £14.48
    This selects the Blade Width of the variant Blade Width
  • Mokuba Japanese Restorer's Cat's Paw Mokuba Japanese Restorer's Cat's Paw
    Out of Stock
    £9.98
  • Japanese Kiridashi Vee Point Marking Knife
  • Japanese Hammer Hakkaku Genno Japanese Hammer Hakkaku Genno
    £20.38 - £24.58
    This selects the Hammer size \ weight of the variant Hammer size \ weight
  • King Japanese Fine & Polishing Waterstones King Japanese Fine & Polishing Waterstones
    This selects the Grit of the variant Grit
  • King Japanese Carver's Stone Set
  • Ice Bear Japanese Coarse Waterstones Ice Bear Japanese Coarse Waterstones
  • Mokuba Japanese Nail Pullers Mokuba Japanese Nail Pullers
    £8.28 - £12.58
    This selects the Working Length of the variant Working Length
  • Ice Bear Japanese Combination Waterstones Ice Bear Japanese Combination Waterstones
  • King Japanese Nagura Stone King Japanese Nagura Stone
  • Ice Bear Japanese Oire Nomi Chisels Ice Bear Japanese Oire Nomi Chisels
  • Ice Bear Waterstone Sharpening Kit Ice Bear Waterstone Sharpening Kit
  • Sun Tiger Gouge Sharpening Cones Sun Tiger Gouge Sharpening Cones
    £28.78 - £42.18
  • Sun Tiger Multiform Water Slipstones Sun Tiger Multiform Water Slipstones
  • Sun Tiger Traditional Shaped Water Slipstones Sun Tiger Traditional Shaped Water Slipstones
  • Mokuba Japanese Double-Ended Nail Set
  • Mokuba Japanese Reform Bar - 300mm
    Out of Stock
    £13.28
  • Ice Bear Japanese Gardener's Root Cutter Ice Bear Japanese Gardener's Root Cutter
Japanese Sharpening Stones
Maintain a keen edge on chisels, plane irons and carving tools with Ice Bear sharpening stones. Choose an appropriate grit for restoring, refining or polishing cutting edges, and follow the recommended soaking or lubrication method for each stone. Explore sharpening options for your bench tools.
