Bosch 18V Tools | Expand Your Bosch 18V Collection
Bosch 18V tools meet the highest standards in speed and precision to provide exceptional results, onsite or at home. Combined with powerful batteries and fast charging technology, take your pick from our ever growing selection of 18V tools and accessories to grow your collection.
See some of our top picks!
When it comes to Bosch 18V tools, we've got it covered. From combi drills, angle grinders, mitre saws and much more, browse some of our favourites and power your toolkit with Bosch 18V tools and accessories!
Bosch 18V tools
Bosch GSB 18V-55 Combi Drill 18V
A tool for all trades, this cordless combi drill ticks all the boxes. Ideal for use in the home or at work, it is suitable for masonry drilling and much more! Compact and lightweight for perfect handling, it features a 2-speed gearbox for powerful screwdriving and drilling as well as a professional quality, full metal 13mm keyless chuck for easy bit changes. A practical belt clip keeps the tool within reach at all times and a LED work light illuminates the working area. Â View product
BOSCH GSB18V-110C BRUSHLESS COMBI DRILL 18V
Next up is another great combi drill from Bosch’s 18V range. The GSB 18V-110 C is a top of the range, tough, no-nonsense combi drill. It is capable of drilling a 16mm hole in masonry and driving large construction screws. This powerful industrial rated tool has a maximum torque of 110Nm. To help handle this much power the GSB 18V-110 C has KickBack Control and an auxiliary handle. 5.0Ah Coolpack batteries, combined with its super efficient brushless motor ensure long runtimes, more holes drilled and more screws driven per battery charge. Maximum life span, with minimum fuss. View product
Bosch GSS 18V-10 Multi-Base Palm Sander in L-BOXX (Body Only)
Enjoy three sanders in one with this lightweight and compact palm sander. With three interchangeable bases and no cables, you can take advantage of cordless flexibility and there's no cables to scratch just finished surfaces. The baseplates accept hook and loop backed abrasive or you can use traditional clamping if you prefer.
Ideal for single-handed use, the multi-base palm sander features an ergonomic soft-grip top for comfortable working. What's more, the microfilter system ensures efficient dust extraction at all times. Supplied in a Bosch L-BOXX 136 storage case. View product
Bosch GCM 18V-216 BITURBO Cordless Mitre Saw 18V (Body Only)
With its high performance Bosch BITURBO brushless motor, this cordless mitre saw produces power equivalent of an 1,600W mains unit! Part of the Bosch 18V family, it uses Bosch ProCORE18V high performance batteries (8Ah+) which provides long runtimes. It is lightweight, maintenance free and the 216mm blade offers 70mm depth of cut. The maximum width of cut is 270mm. It features a depth stop for trenching, a laser line and LED light for accurate alignment and an ergonomic carry handle. Supplied as a body only tool, the mitre angle range is 47° left and right. View product
More Bosch 18V tools...
Bosch GST 18 V-LI B Bow Grip Jigsaw 18V In L-BOXX (Body Only)
Cordless, powerful, compact and well balanced, this bow grip jigsaw is brilliant for a wide range of tasks. Featuring 4-stage pendulum action and variable speed trigger, the bow handle with comfort grip panels reduces fatigue and vibration. What's more, the SDS quick-change blade system means you can change the blade with only one hand. There's also a LED work light and cut line blower for increased visibility. Purchase this tool and utilise batteries from other tools in the 18V family to grow your collection. Supplied in a Bosch L-BOXX 136 storage case. View product
Bosch GSA 18 V-LI C Compact Sabre 18V in L-BOXX
Ideal for electrical or plumbing installation and remodelling, this compact sabre saw is a versatile tool. Perfectly balanced and lightweight, it is simple to use one-handed and is great for overhead working where access is limited. With its variable cutting speed, the sabre saw is suitable for use on a wide range of materials. It features an LED light for increased visibility during sawing. The SoftGrip handle and low vibration levels help to minimise fatigue. Finally, thanks to the SDS tool-free collar, you'll enjoy simple blade changes. Supplied with L-BOXX. View product
Discover X-LOCK technology...
Bosch GWX 18V-8 Angle Grinder 125mm & L-Boxx 18V (Body Only)
Next, this lightweight, compact 125mm cordless angle grinder is a great addition to your tool arsenal. With a durable 4-pole high performance motor, it delivers excellent power, potential and manoeuvrability. The angle grinder features Bosch's X-LOCK, tool-free accessory changing system. The one click accessory mounting system offers fast, safe and secure blade changes. Lastly, this model will also take the standard 125mm angle cutting and grinding discs for added convenience. View product
Bosch 18V accessories
Before we take a look at some of our Bosch accessory top picks, why not read our article about how to choose the perfect Bosch battery to suit your needs?
Bosch GBA18V ProCORE Li-Ion High Performance Battery 18V (4.0Ah)
A new dimension of power for all Bosch 18V power tools, Bosch ProCORE18V batteries (4.0Ah, 8.0Ah and 12.0Ah) are their most powerful batteries ever. This is thanks to the latest cell technology and superior heat management. You'll not only enjoy 87% more power with the latest generation high capacity cells but also 135% longer life thanks to CoolPack 2.0 technology.
100% compatible with Bosch Professional 18V power tools and chargers, the power output of this 4.0Ah battery is similar to an 800W mains powered device. Other benefits include the fact the battery is compact and lighter in weight compared to most standard 4.0Ah batteries and there's a battery level indicator which is similar to having a fuel gauge on your car. When other batteries cannot handle the heat and switch off, ProCORE 18V batteries power through! View product
Bosch CoolPack Li-Ion Battery 18V (5.0Ah)
Forming part of the Bosch 18V family of accessories, this Bosch battery offers exceptional lifetime and performance from Bosch technology. This 5.0Ah Li-Ion CoolPack has a superb runtime, intelligent power management, battery level indicator and built in electronic cell protection (ECP), you'll enjoy protection against overload, overheating and total discharge. The best part? The CoolPack battery manages heat which means you can work as fast as you need to. View product
Discover more…
Did you enjoy this article? Take a look at the 3 tier performance range of brushless 18V combi drills from Bosch; it's definitely worth a read!
Next, learn more about the Bosch GCM 18V-216 BITURBO Mitre Saw. Ideal for a wide variety of applications, the mitre saw is a fantastic choice wherever you are working. With comparable power of an 1600 watt corded machine, the BITURBO tool has been specifically designed and optimised to work with the Bosch ProCORE18V battery platform.
Finally, why not find out more about Starlock by Bosch with another of our helpful guides. Starlock, a joint venture between Bosch and FEIN, is a patented blade mounting system that provides a very fast ‘snap in’ blade fitting. In recent years, the Starlock system has set the new standard for multi-tools and accessories.
Get in touch!
If you’ve bought the any of the above Bosch 18V tools, we’d love to hear from you. Comment below or send us a photograph and tell us all about your purchase. Alternatively, get in touch via our social media platforms. Find us on Facebook or connect with us on Instagram using #bosch18vtools to @AxminsterTools.
