A Guide to Hand Plane Types
Understanding the Types of Hand Planes
Each hand plane is designed with a specific purpose in mind. Here's a breakdown of the most popular types:
  • Smoothing Planes
    Ideal for final surface preparation, leaving timber silky smooth and ready for finishing.
  • Jack Planes
    A versatile all-rounder used for rough dimensioning and general flattening.
  • Fore Planes
    Longer than jack planes, they’re great for flattening large boards and preparing surfaces for finer work.
  • Block Planes
    Compact and easy to handle, perfect for trimming end grain and small adjustments.
  • Router Planes
    Used for cleaning out recesses like dados and grooves with precision.
  • Rabbet (or Rebate) Planes
    Designed to cut rabbets along the edge of a board.
  • Shoulder Planes
    Similar to rabbet planes but with finer control, ideal for trimming tenons and shoulders.
  • Bench Planes
    A category that includes jack, fore, and smoothing planes—your go-to tools for general planing tasks.
Explore hand planes
Choosing the Right Plane
The best plane for the job depends on the task at hand. For example:
  • Preparing rough stock? Start with a jack or fore plane.
  • Finishing a surface? Reach for a smoothing or scraper plane.
  • Cutting joinery? A shoulder or rabbet plane will give you clean, accurate results.
Understanding the characteristics of each plane helps you work more efficiently and achieve better results.
Choosing a plane
Maintenance & Sharpening
A well-maintained plane is a joy to use. Here are a few tips:
  • Keep blades sharp
    Regular honing ensures clean cuts and reduces effort.
  • Check the sole
    A flat sole is essential for accuracy. Flatten it if needed using abrasive paper on a flat surface.
  • Lubricate moving parts
    A light oil prevents rust and keeps adjustments smooth.
  • Store properly
    Keep planes dry and off metal surfaces to avoid corrosion.
Care and maintenance
Explore maintenance & sharpening
Quick Tips at a Glance
  • Smoothing planes are perfect for final surface prep.
  • Jack planes are your go-to for general-purpose planing.
  • Fore planes excel at flattening large boards.
  • Block planes are ideal for trimming end grain.
  • Router planes clean out grooves and recesses.
  • Rabbet and shoulder planes are essential for joinery.
  • Plough planes cut grooves for panels and drawers.
  • Scraper planes tame difficult grain with ease.
  • Keep blades sharp and soles flat for best results.
  • Choose the right plane for the job to save time and effort.
Tips
Discover more...
If you've enjoyed reading this guide, why not take a look at some of our other blogs?
Get in touch!
If you’ve used a certain type of hand plane for one of your projects, or have bought one of our planes, we'd love to hear from you. Comment below or send us a photograph and tell us all about what you've been up to, or what you've bought.
Alternatively, get in touch via our social media platforms. Find us on Facebook or Instagram.
