Must-have woodworking accessories for your CNC Router...
UJK Rail Clamp MFT Top
Upgrade the supplied MDF spoil board from your i2R CNC Router to this precision-engineered, T-slot top made from durable birch play. Follow these easy steps:
  1. Remove the MDF spoil board
  2. Simply drill holes in each corner of the UJK MFT Top corresponding to the fixtures on the i2R CNC Router bed
  3. Secure the UJK top to the machine using the original i2R hardware
This gives you quick and accurate referencing. Clock the gantry against the edge of the MFT top to guarantee that it's square, then every time you use the MFT holes for workholding, you can guarantee your work is square.
Shop now
Once you're set up with the MFT Top on your i2R CNC Router, the world is your oyster. Take advantage of all of these woodworking accessories and feel the efficiency...
UJK Assembly Square
An essential tool for precise assembly and mitre cuts when using a CNC router. Highly accurate and CNC-machined in thick HDF Valchromat.
Shop now
UJK Workholding Accessory Kit
A comprehensive set of cutting and clamping accessories designed for use on an MFT top. Includes 23 accessories supplied in a T-loc case. These clamping methods are low-profile and flush, removing the need to pause CNC cutting to relocate clamps that are in the way of the toolpath.
Shop now
If you accidentally machine into either the assembly square or workholding accessory kit, you won't damage your valuable cutters, so you can feel relaxed while machining.
Once you have your work holding set up, you can easily run a series of repeat pieces without realigning, increasing your production efficiency.
UJK MFT Hook Stop
This versatile accessory features a unique hook that ensures precise material placement and stability - perfect for detailed CNC work.
Shop now
UJK Self Adjusting Toggle Clamps with Dogs
UJK's industrial-quality clamps automatically adjust to the thickness of your workpiece, ensuring a firm hold-down. They are perfect for use on an MFT top, making your CNC projects more efficient and precise.
Shop UJK Self Adjusting Toggle Clamp Push/Pull 25 & Dog
Shop UJK Self Adjusting Toggle Clamp 50 & Dog
UJK 12mm Guide Dogs
These guide dogs are low-profile, CNC-machined accessories designed to fit precisely into 20mm holes of an MFT top. This ensures accurate and stable positioning of materials, making it ideal for use with CNC routers.
Shop now
What would be your top product to use with your CNC Router? Let us know in the comments below or by sharing on your socials. Give some of the best-selling accessories a go and watch your CNC work thrive.
