Measuring and Marking
In this blog, we will explore the various types of measuring and marking devices, their uses, and where you can find high-quality tools to enhance your woodworking experience.
Rules
Precision rules bring accuracy to your workshop, ensuring every measurement is exact and reliable.
Bench Rule: A bench rule, typically made of metal or wood, is a straight, flat ruler. Woodworkers use it for measuring and drawing straight lines on wood. Its rigid structure ensures accuracy, making it a staple in any woodworker's toolkit.
Folding Rule: Also known as a zig-zag rule, the folding rule is a flexible measuring tool that can be extended and folded. It is particularly useful for measuring longer distances that a standard ruler cannot cover. Its compact design makes it easy to carry and store.
Shop now
Tape Measures
The tape measure, or tape rule, is a retractable measuring tool essential for measuring lengths and widths. It is highly versatile and can be used for a variety of tasks, from measuring large pieces of wood to checking the dimensions of a room.
Shop now
Squares, Bevels, and Angle Measuring
Essential tools for marking at 90 degrees or any other angle, ensuring precise cuts and joints.
Try Square: A try square marks and checks right angles (90 degrees). It consists of a blade and a handle, and it is crucial for ensuring that your cuts are perfectly square.
Combination Square: The combination square is one of the most versatile tools in woodworking. It can function as a try square, 45° mitre square, rule, depth gauge, marking gauge, and level. This multi-functional tool is indispensable for general setting out.
T Bevel: Also known as a sliding bevel, the T bevel transfers angles from one piece of work to another. Its adjustable blade allows you to set and replicate any angle, making it ideal for complex joinery.
Framing Square: The framing square, or carpenter's square, is a large L-shaped tool used for laying out and checking right angles. It is essential for framing, roofing, and stairway work.
Shop now
Gauges
Gauges of all types provide accurate measurement and marking out, crucial for detailed woodworking tasks.
A marking gauge scribes lines parallel to a reference edge. It consists of a beam, a headstock, and a scribing pin or knife. This tool ensures consistent and accurate markings for cutting and joinery.
Shop now
Pencils, Scribes, and Markers
These tools are used to mark materials accurately, ensuring clear and precise guidelines for cutting and assembly.
Awl: An awl is a pointed tool used for marking and starting holes in wood. It is particularly useful for creating pilot holes for screws and nails, ensuring they are placed accurately.
Divider: A divider is a tool with two pointed legs used for scribing circles or arcs and transferring measurements. It is particularly useful for marking out equal distances and creating precise layouts.
Shop now
Marking Knives
Marking knives are essential tools for any woodworker, providing precision and accuracy in marking out cuts and joinery. Unlike pencils, marking knives create fine, crisp lines that are easy to follow and ensure a higher level of accuracy.
Shop now
Levels and Laser Levels
Laser lines and levels are perfect for site and construction trades, ensuring your work is perfectly horizontal or vertical.
Shop now
Centre Finders
Centre finders help locate the middle of your project, ensuring balanced and symmetrical designs.
Shop now
Centre Punches
Essential for marking the exact centre of a hole before drilling, ensuring accuracy and preventing drill bit slippage.
Shop now
Drawing Equipment
Use drawing equipment to create curvaceous shapes with ease, perfect for detailed and artistic woodworking.
Shop now
Calipers, Compasses, and Dividers
These tools are essential for measuring and marking precise distances, diameters, and arcs.
Shop now
Laying Out Tools
Lay out or transfer measurements quickly and accurately with these essential tools.
Shop now
Straight Edges and Surface Plates
Straight edges and surface plates in steel, aluminium, cast iron, and granite ensure flatness and precision in your projects.
Shop now
Trammels
Trammels are adjustable marking tools used for drawing large circles or arcs. They can be fitted with various attachments such as pencils, pens, or scribing points, making them versatile for different marking needs.
In conclusion, mastering the use of measuring and marking tools is essential for any woodworker. By investing in quality tools and learning how to use them effectively, you can ensure that your woodworking projects are precise and professional. Whether you are a beginner or an experienced woodworker, the right tools from Axminster Tools will help you achieve impeccable results every time.
For high-quality measuring and marking tools, Axminster Tools offers a wide range of products that cater to both amateur and professional woodworkers. Our selection includes everything from bench rules and tape measures to combination squares and marking gauges. You can explore our extensive range of tools and products on our website or visit one of our stores.
Shop now
