Woodworking Wisdom
Building Your Ideal Workbench With UJK
UJK Multifunction Workbench Mk II
A workbench is the centre of your workshop. It’s where accuracy matters, where projects take shape and where frustration quickly shows if your setup isn’t right. The UJK Multifunction Workbench Mk II has been designed as a long‑term solution - a premium, modular system that adapts to the way you work, not the other way around.
Built with precision, durability and flexibility at its core, the UJK system allows you to start with a solid foundation and build a workbench that suits your space, your projects and your ambitions.
The foundation: UJK Multifunction Workbench Mk II Frame
Every UJK setup starts with the Mk II workbench frame, manufactured in Britain from high‑quality birch plywood. Cross‑grain construction, with each layer set at right angles to the next, delivers exceptional rigidity and long‑term dimensional stability. The combination of an 18mm outer frame and 12mm inner frame ensures the structure stays flat, true and dependable, even under heavy use.
The distinctive Heksa hex‑grip surface on all four sides improves clamping grip while offering resistance to moisture, weathering and common workshop chemicals. The front and rear aprons feature 20mm bench dog holes and integrated T‑track on both sides, with the hole pattern aligned to match the 20mm holes in compatible UJK worktops. This allows clamps, dogs and accessories to reference accurately from the worktop surface down the sides of the frame, making it particularly useful for square, repeatable assembly and holding projects securely during glue‑ups.
If you value accuracy, repeatability and a bench that won’t let you down over time, this frame is where that confidence begins.
Integrated 20 x 20mm bench dog holes and T‑track on both sides
Choosing your support: Trestles or Sawhorses?
One of the key buying decisions is how you want to support your workbench. UJK offers two excellent options, each designed around different working styles.
UJK Multifunction Workbench Mk II with Telescopic Trestles
Telescopic Trestles: For precision and control
The UJK Telescopic Trestles are ideal if you want a workshop‑style setup with maximum control over working height and clamping access. Manufactured from durable steel, they offer exceptional rigidity and long‑term reliability. The telescopic height adjustment allows you to fine‑tune your working position, reducing fatigue and improving accuracy, particularly important for detailed joinery or repetitive tasks.
Wide footprints with rubber feet provide outstanding stability, while the top rails are designed for accurate side clamping. A lower rail on each trestle keeps tools close to hand, helping you work more efficiently.
Choose trestles if you want a more permanent workshop feel, adjustable working height and maximum precision.
Sawhorses: For portability and versatility
The UJK Sawhorses are designed for strength, speed and portability. Supplied as a pair, these all‑steel sawhorses fold flat for easy transport and storage, making them ideal for site work or workshops where space is at a premium. Quick‑release setup means you can be up and working in moments.
UJK Multifunction Workbench Mk II with Sawhorses
Despite their portability, they’re impressively strong. A wide stance, rubber feet and reinforced top rail provide excellent stability, while telescopic legs allow height adjustment to suit different tasks. This makes them perfect for users who need a robust bench one day and a portable setup the next.
Choose sawhorses if you value portability, fast setup and a bench that can move easily between workshop and site.
Choosing the Right Worktop
Once you’ve selected your frame and support, the final step is choosing a work surface that matches how you work. UJK offers a range of precision‑made worktops designed around different clamping systems, or you can create your own bespoke top using the Parf Guide System.
Moisture Resistant MDF Top for Bench Dogs
HDF Valchromat Top for Parf Dogs
Rail Clamp MFT Top
Ideal for users of the UJK Parf system, offering precise hole alignment for accurate cutting, routing and repeatable setups.
A cost‑effective, hard‑wearing surface suited to traditional bench dogs and everyday workshop use.
Rail Clamp MFT Top
Optimised for use with guide rails and rail clamps, making it ideal for accurate sheet material cutting and panel processing.
Each top allows you to tailor clamping, alignment and workflow, ensuring your bench supports the way you like to work.
Why choose UJK?
UJK products are designed with one clear goal: to make woodworking more accurate, more efficient and more enjoyable. Every component in the Multifunction Workbench Mk II system reflects this, from the precision‑engineered plywood frame to the robust steel supports and thoughtfully designed accessories.
This isn’t a disposable bench or a one‑size‑fits‑all solution. It’s a system built to grow with you, adapt to new projects and reward good technique.
Build once. Work better.
The UJK Multifunction Workbench Mk II gives you the freedom to build the setup you need today, with the confidence that it can evolve as your skills, space and projects develop. Start with a solid frame, choose the support that suits your working style, and finish with a worktop that brings accuracy and control to every job.
If you’re serious about your workshop, this is a workbench you’ll enjoy using - every single time you step up to it.
Start building your bench
Leave a comment
