Titebond Glue - Which glue for you?
Titebond comparison
Titebond is the largest manufacturer of wood glues and has a glue to suit every woodworker, from the pro cabinetmaker to the DIYer. Used every day across the world Titebond is the first choice for woodworkers. Find the right glue for you below and choose a product in the table for detailed information.
Interior
Best used for | Open / closed time | |
Original | Furniture, musical instruments | 5 / 10 minutes |
Extend | Wood-to-wood lay-ups requiring longer assembly time | 15 / 10 minutes |
Liquid Hide | Musical instruments, long assembly time | 10 / 20 minutes |
Quick & Thick | Wood, pottery, stone, glass, fabrics, leather and most craft materials | 5 / 10 minutes |
No-Run, No-Drip | Perfect for finish trim or mouldings | 5 / 10 minutes |
Cold Press for Veneer | Veneering using cold press | 15 / 5 minutes |
Instant | Wood, metal and rubber | 5 / 3 seconds |
Exterior
II Premium | Humid interior, food cutting boards and mitre joints | 5 / 10 minutes |
II Dark | Dark wood species, interior or humid environment | 5 / 10 minutes |
III Ultimate | Long assembly time. The only waterproof wood glue that cleans up with water (while wet). | 10 / 20 minutes |
Polyurethane | Exterior, non-porous materials | 20 minutes in total |
Construction adhesive
Heavy Duty | Gap filling applications involving wood, metal, brick and stone | 10 / 20 minutes |
Heavy Duty Solvent Free | Wood to porous material requiring gap filling, foam, remodelling inhabited structures | 10 / 20 minutes |
Polyurethane | Non-porous or porous materials, gap filling. | 15 / 20 minutes |
Interior range
Titebond Original
Type: Aliphatic resin, interior wood glue.
Ideal for: Furniture, cabinet making, biscuit joints.
Bonds: Wood, hardboard, particleboard, leather, cloth and most other porous materials.
- Strong initial tack time and bonds stronger than wood
- Cleans up easily with water in application or sanding when dry
- Open/Close time 5/10 minutes, clamping time for an unstressed joint - 30 minutes/1 hour. Stressed joint - 24 hours
- Unaffected by finishes
Titebond Original Wood GlueFrom £7.78 £6.48
Titebond Extend
Type: Slower setting version of Titebond Original interior wood glue, has a longer opening time to apply and assemble.
Ideal for: Complex tasks such as curved railings, edge and face gluing. It has a higher heat resistance than Original, making it more suitable for interior applications that are exposed to higher heat; kitchens, fire surround and radiator covers.
Bonds: Wood, hardboard, particleboard, MDF, plywood leather, cloth and most other porous materials.
- Open/Close time 15/25 minutes
Titebond Extend Wood GlueFrom £14.98 £12.48
Titebond Liquid Hide
Type: Natural Protein Emulsion; ready-to- use, interior hide glue that doesn't require heating, mixing or stirring.
Ideal for: Furniture repair and can be used to give a unique crackling effect on wood, can also be used on cloth, or for small veneering jobs.
Bonds: Wood and Cloth.
- Long assembly time allows time careful applications for complex tasks
- Open/Close time 10/30 minutes
Titebond Liquid Hide GlueFrom £8.78 £7.32
Titebond Quick & Thick Multi-Surface
Type: Thixotropic PVA.
Ideal for: Workshop, home and craft projects. It's the thickest and fastest drying waterbased glue available.
Bonds: Porous or semi-porous materials – ideal for wood, pottery, ceramic, stone, glass, fabrics and leather.
- Provides a strong initial tack with a fast setting speed (open/close time 5/10 minutes)
- Allows enough time to realign your workpieces
- Dries clear and is paintable
Titebond Quick & Thick Multi-Surface GlueFrom £8.78 £7.32 From £6.14
Titebond No-Run, No-Drip
Type: Thixotropic PVA, interior wood moulding glue.
Ideal for: Finish trims or mouldings, baseboards and window casings. It’s thick and fast drying, the viscosity allows it to be used vertically and overhead.
Bonds: Wood, cloth and leather and most porous and semi porous materials.
Titebond Quick & Thick Wood Glue - 473mlFrom £11.68 £9.73 From £8.17
Type: Polyvinyl Acetate, high-quality, economical alternative to contact cement for large-scale bonding of veneers to flat surfaces as it contains none of the harmful or corrosive fumes found in most contact adhesives.
Ideal for: Specifically formulated for cold press laminating, interior use.
Bonds: Wood to solid woods, particleboard, MDF, plywood and other porous materials.
- Cleans up easily with water in application or scrape or sand off when dry
- Open/Close time 15/5 minutes
Titebond Cold Press for VeneerFrom £16.98 £14.15
Titebond Instant
Type: Cyanoacrylates (CA) traditionally called superglue, nearly instant setting time.
Ideal for: With incredible strength and impact resistant, it can be used for a variety of applications, providing a strong, permanent bond.
Bonds: Wood, plastics, china, ceramic, glass and rubber.
Available in four forms
Thin: Handling time of 5 seconds and a setting time of 3 seconds. Perfect for running into hairline cracks for repairs and small sections of timber.
Medium: Handling time of 7 seconds and a setting time of 5 seconds. More general purpose type of CA glue.
Thick: Handling time of 10 seconds and a setting time of 8 seconds. Ideal for use on porous wood, MDF and trimming carpentry components.
Gel: Handling time of 30 seconds and a setting time of 20 seconds. Excellent gap filling properties, ideal for use on porous wood.
- Clean up using Acetone in application, sanding when dry
Titebond Instant GluesFrom £19.98 £16.65
Exterior range
Titebond II Premium
Type: Crosslinking PVA with type II water resistance. An interior and exterior wood glue.
Ideal for: Outdoor projects including outdoor furniture, birdhouses, planters and picnic tables as well as humid interiors. It’s FDA approved for indirect food contact, ideal for items such as chopping boards.
Bonds: Wood, cloth and leather.
- Strong initial tack time and high bond strength
- Open/Close time 5/10 minutes, clamping time for an unstressed joint - 30 minutes/1 hour Stressed joint - 24 hours
Titebond II Premium Wood GlueFrom £9.78 £8.15
Titebond II Premium Dark
Ideal for: This is a dyed version of Titebond II Premium, for use on darker coloured timber. It has all of the same properties and advantages, but dries a dark brown colour.
Titebond II Dark Wood GlueFrom £9.78 £8.15 From £6.85
Titebond III Ultimate
Type: Advanced Proprietary Polymer with type 1 water resistance. An interior and exterior wood glue.
Ideal for: Outdoor projects especially in cooler temperatures. Has excellent water-resistance and is FDA approved for indirect food contact.
- Strong initial tack and longer opening time allows more time when aligning parts
- Open/Close time 10/20 minutes
- Has the ease of application of aliphatic/PVAs and the water resistance of polyurethane glue without the cleanup problems
- Unaffected by finishes, solvents, heat and is mildew resistant
Titebond III Ultimate Wood GlueFrom £10.98 £9.15
Titebond Polyurethane
Type: Polyurethane; very strong with type II water resistance. An interior and exterior glue.
Ideal for: Bonding two different materials to each other, with an Epoxy like strength.
Bonds: Virtually anything including wood, metals, ceramics and most plastics.
- Initial tack time of 30 minutes (non drip), short clamping time of 45 minutes. Fast setting time of 4 hours (approx.)
- Cleans up with white spirit in application, scrape or sand off excess when dry
- 100% waterproof (Type II water resistance)
- Use of disposable gloves advised
Construction range
Titebond Heavy Duty Construction Adhesive
Type: Solvent based rubber-resin, designed for a wide range of construction applications that require a strong gap filling bond.
Ideal for: Interior and exterior work, used in all common building materials; provides a strong grab, fills gaps and irregularities and will remain permanently flexible.
Bonds: Wood, metal, brick, concrete, ceramics, plywood, plasterboard and treated timber.
- Approximately working time of 10-20 minutes for a 1/4" bead
- Clean up by scraping off dried excess with a putty knife. Remove residue with mineral spirits or equivalent solvent in application
- Reduces the amount of nails in tasks
- Water resistant
Titebond Heavy Duty Solvent Free Construction Adhesive
Type: Water based vinyl acrylic, solvent free adhesive. Designed to the same specification as Titebond Heavy Duty Construction Adhesive, with the added benefits of being environmentally friendly, by not containing any ozone depleting chemicals and doesn’t have a high potency smell.
- Approximately working time of 20 minutes for a 1/4" bead
- Cleans up with water in application, scrape or sand off when dry
- Water resistant
- Environmentally safe - VOC Compliant
Titebond Solvent Free Construction AdhesiveFrom £4.88 £4.07
Titebond Polyurethane Construction Adhesive
Type: Polyurethane construction adhesive, with added benefits of being environmentally friendly, by not containing any ozone depleting chemicals and doesn’t have a high potency smell. Offers strength and durability.
Ideal for: Interior and exterior construction projects, fast setting even in cold temperatures with a smooth bead, fast cure and minimal shrinkage - even in near freezing temperatures.
Bonds: All common building materials, including; wet, frozen, engineered and treated lumber, metal, plastic, foam, mirror, concrete and brick.
- Close time of 30 minutes.
- Clean up by scraping off dried excess with a putty knife. Remove residue with mineral spirits or equivalent solvent in application.
- 100% Waterproof
It would be helpful to edit out the Americanisms in this explanation. What are "mineral spirits" and who are the FDA, and why do we care? What is "molding"?
The point of liquid hide glue in instrument building is to provide reversibility, e.g. so that, if necessary, a neck can be removed from the body in the future. It has nothing to do a longer open time - which it doesn't really have in any case.
I agree with Pete Olson about musical instruments, the question I would ask is 'How brittle are the glues after setting'. Some instruments attach leather to card or wood and want any residual glue to crack upon first bending leaving a very flexible, but air-tight, join. Any ideals? Is your hide glue brittle if flexed?
