Woodworking Terms
Here are some general woodworking terms and basic board terminology commonly used in woodworking.
Grain: The direction, pattern, and texture of wood fibres within a piece of wood.
Joinery: The process of joining two or more pieces of wood together using various techniques such as dovetail joints, mortise and tenon joints, and dowel joints.
Mitre joint: A joint created by joining two pieces of wood at a 45-degree angle to form a corner.
Dado joint:  A woodworking joint where you create a rectangular groove or channel across the grain of a workpiece to accommodate another piece of wood.
Rabbet: A groove or notch cut into the edge of a board to allow another board to fit into it.
Chamfer: Bevelling or cutting the edge of a board at an angle, often for decorative purposes.
Dowel: A cylindrical wooden rod used to strengthen joints or align pieces of wood.
Router: A power tool used for shaping and cutting designs, grooves, and edges in wood.
Sanding: The process of smoothing a surface using sandpaper or a sanding machine.
Varnish: A protective finish applied to wood to enhance its appearance and durability.
Stain: A colouring agent applied to wood to alter its natural colour and enhance its grain pattern.
Discover more...
If you’ve enjoyed reading this article, keep an eye out for more woodworking articles to develop your knowledge and skill over time.
Get connected!
Follow us on Instagram and Facebook to stay up to date on all the latest from our Woodworking Wisdom platform. Connect with us @AxminsterTools.
