Axminster Workshop Abrasive Discs 125mm (Pkt 12) - Mixed
- 12 assorted discs
- Contents; 4 x 60, 4 x 120, and 4 x 240 grit
- 125mm diameter, pre-punched
- Suitable for most 125mm random orbit sanders
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £30.28 £25.23
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.68 £11.40
A pack of 12 assorted 125mm diameter pre-punched hook and loop discs to fit most 125mm random orbit sanders. Contains 4 x 60, 4 x 120, and 4 x 240 grit discs.
Abrasive Backing | Paper and Hook and loop |
Abrasive Disc Diameter | 125 mm |
Abrasive Grit | Mixed |
EAN Barcode | 5052511002405 |
