This 8 piece set is invaluable for a wide variety of applications and is ideal for sign-making. Every bit is manufactured according to Amana's stringent quality standards for optimum performance and long life in use.
This versatile set includes the following:
Solid Carbide Spiral Plunge for Solid Wood 1/4 Dia x 1 Inch x 1/4 Shank Down-Cut
Solid Carbide Spiral Plunge for Solid Wood 1/8 Dia x 1/2 x 1/4 Inch Shank Down-Cut
Solid Carbide Up-Cut Spiral Ball Nose 3/32 Radius x 3/16 Dia x 1/2 x 1/4 Shank x 2-1/2 Inch Long x 2 Flute Router Bit
Solid Carbide Up-Cut Spiral Ball Nose 1/8 Radius x 1/4 Dia x 1/2 x 1/4 Shank x 2-1/2 Inch Long x 2 Flute Router Bit
CNC 2D and 3D Carving 5.4 Deg Tapered Angle Ball Tip 1/16 Dia x 1/32 Radius x 1 x 1/4 Shank x 3 Inch Long x 4 Flute Solid Carbide Up-Cut Spiral ZrN Coated Router Bit
Solid Carbide Spiral Plunge for Solid Wood 1/4 Dia x 1 Inch x 1/4 Shank Up-Cut 1
Carbide Tipped V-Groove 90 Deg x 1/2 Dia x 1/4 x 1/4 Inch Shank
Carbide Tipped V-Groove 60 Deg x 1/2 Dia x 7/16 x 1/4 Inch Shank
