Amana 8 Piece General Purpose CNC Router Cutter Set AMS174 1/4" Shank
111651
111651
From £208.18 £173.48
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Wide variety of applications
  • Stored in wooden showcase box
  • 8 piece set
  • Includes Spektraâ„¢ bits
This 8 piece set is designed for a wide variety of applications and is ideal for sign-making. Every bit is manufactured according to Amana's stringent quality standards for optimum performance and long life in use. This set also includes specialist Spektra™ bits, which feature a nACo® nanocomposite coating for extreme nanohardness and heat resistance.
This comprehensive set includes the following:
Carbide Tipped "Zero Point" V-Groove 60 Deg x 1/2 Dia x 13/32 x 1/4 Inch Shank
Carbide Tipped "Zero Point" V-Groove 90 Deg x 3/8 Dia x 11/64 x 1/4 Inch Shank
Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Spiral Plunge 1/8 Dia x 1/2 x 1/4 Inch Shank
Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Spiral Plunge 1/4 Dia x 3/4 x 1/4 Inch Shank
CNC 2D and 3D Carving 5.4 Deg Tapered Angle Ball Tip 1/16 Dia x 1/32 Radius x 1 x 1/4 Shank x 3 Inch Long x 4 Flute Solid Carbide Up-Cut Spiral Spektraâ„¢ Extreme Tool Life Coated Router Bit
Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Up-Cut Ball Nose Spiral 1/8 Radius x 1/4 Dia x 1 Inch x 1/4 Shank Router Bit
Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Spiral Plunge 3/16 Dia x 3/4 x 1/4 Inch Shank
Solid Carbide 30 Degree Engraving 0.005 Tip Width x 1/4 Inch Shank Signmaking Spektraâ„¢ Extreme Tool Life Coated Router Bit
Designed for cutting:
Composite
Fiberglass
Fiberglass PCB Board
Graphite
MDF/HDF
Phenolic Composites
Plastic, PVC & Acrylic
Plexiglas®
Sign Foam, Sign Board & HDU
Wood
Durabond
With a brilliant distinctively-tinted coloring, the Spektraâ„¢ nACo nanocomposite coating provides additional improvements in four critical aspects of router tooling.
• nACo coating is a micro-thin ceramic coating which enables the tool's cutting edge to retain crucial sharpness and lubricity. This provides longevity and produces cutting results of the highest quality.
• Coating prevents high heat and oxidation which is detrimental to cutting tool performance.
• Multi-colored hues, while attractive, will dissipate upon use and yet coating will remain fully effective.
• nACo offers approximately 4,500 Vickers for impressive solid hardness on cutting areas of the tool, for an increase up to 2.5 times compared to uncoated bits.
Note: Blue based color dissipates immediately upon use. nACo® nanocomposite coating will not wear off.
Suitable for use with CNC Routers and shouldn't be used with a handheld router.
