Amana Carbide Insert Spoilboard Router Cutter 1/2" Shank
111587
From £256.73 £213.94
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock
  • Spoilboard surfacing and chamfering
  • 4-sided carbide inserts
  • Fast material removal
  • Suitable for MDF and fibreboard
This 3 wing spoilboard cutter is designed for surfacing and chamfering. It's great for planing large surfaces and can remove fine layers of material with ease. It features 3 wings or flutes, each with a 4-sided solid carbide insert knife, which gives maximum cutting efficiency and fast material removal. The higher number of teeth also allows for higher feed rates. The 3 wing design results in a more balanced tool while running and its unique chamfer corner insert design produces a flawless surface.
It is ideal for resurfacing spoilboards and planing large glued up panels using CNC, surfacing and finishing wood using timber slab machines, and rabbeting / slotting. The tool is capable of plunging to a maximum depth of 6mm (1/4") before commencing resurfacing. It is able to remove as little as 0.001" layer of material per pass, if desired.
This cutter is designed for use with the following materials:
MDF
Fiberboard
HDF/LDF
Also able to cut:
Balsa Core
Epoxy (Epoxy Resins)
High Density Urethane (HDU Board)
Plastic/Acrylic*
Plywood/Chipboard
Hardwood/Softwood
Ultra-High-Molecular-Weight Polyethylene (UHMWPE)
* Use lower CNC spindle RPM and adjusted feed-rate to prevent melting and adhesion of the acrylic material to the tool.
Suitable for use with CNC Routers and shouldn't be used with a handheld router. Also suitable for router sled machines. Warning: make sure that your router sled rails are fully stable and squared.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
