Amana Carbide Tipped Double Edge Folding Vee Groove 1/4" Shank
111581
111581
From £38.68 £32.23
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • 108 deg, 0.9" tip
  • Carbide tipped v-groove
  • Use with Aluminium Composite Materials (ACM)
This router bit is designed for cutting, scoring and shaping Aluminium Composite Materials (ACM) using flat bottom V-grooves. The V-shaped grooves remove the aluminium cover and some polyethylene core, allowing the material to be folded or creased. ACM is widely used in wall panel fabrication, and a range of interior and exterior cladding applications, such as office buildings, hospitals, airports and hotels.
This cutter is designed for use in the following materials:
Acetate
Aluminum, Brass, Bronze, Clay, Zinc & Wood Composite Panels
Aluminum 5052
Aluminum Composite Materials (ACM)
Aluminum Composite Panel (ACP)
ALPOLIC® Copper Composite Material (CCM)
Alucobond®
Alupanel®
Bakelite
Dibond®
Durabond
e-panelâ„¢
Etalbond®
Nylon
PE and FR Cores
Phenolics
Plastic/Acrylic
Plexiglas®
PVC
Thermoplastics
Titanium Composite Material (TCM)
Wood
Suitable for use in a CNC router, router table and handheld router.
