Amana Carbide Tipped Straight Plunge Router Cutters 1/2" Shank
- AMAX harder carbide
- Two flute design
- Ideal for cutting wood, MDF and plywood
Amana 8 Piece General Purpose CNC Router Cutter Set AMS174 1/4" ShankFrom £208.18 £173.48
Amana Master CNC Router Cutter Set with Display & 57 CuttersFrom £2,050.98 £1,709.15
These router bits feature a two-flute design for a very fine finish. The two flutes balance the cutting bit, which reduces any vibration that would degrade the finish. They make two cuts per revolution which produces a smooth surface, but must be at a slightly reduced feed rate.
This range of bits from Amana are manufactured in their AMAX Extended Life carbide, which offers a number of benefits:
Increased life by 200% even when working with abrasive materials
Superior geometric design
Improved resistance to wear
Super clean cuts
These bits are excellent for cutting the following materials:
Wood
MDF
Plywood
Suitable for use with CNC routers, router tables and handheld routers.
