Amana Master CNC Router Cutter Set with Display & 57 Cutters
111648
111648
From £2,050.98 £1,709.15
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Out of Stock
  • 57 versatile router bits
  • Presented in solid wood display
  • Use for a variety of applications
  • Bit for cutting most materials
  • High quality CNC router bits
This comprehensive collection of 57 CNC router bits from Amana will virtually guarantee you have a tool for every application. Every bit in this set is manufactured to Amana's stringent high standards for high performance and long tool life. The collection is stored in a solid wood display which can be freestanding or wall mounted, has LED illumination, mirrored interior and locking clear acrylic door.
There is a range of CNC router bits included, across a mixture of tool types, styles and designs, including solid carbide tipped, carbide insert knives, superior "mirror finish" cutting edges, and different material types for different applications. Possible uses include: signmaking, engraving, cabinet making, material surfacing, and more.
This set can be used to cut the following materials:
Aluminum Brass Bronze Copper
Gold Silver & Titanium
Aluminum Composite Material (ACM)
Aluminum FoamCore
Composite
Corrugated Polyproplene
Fiberglass
Fiberglass PCB Board
FoamCore
Gatorfoam®
Graphite
Melamine
MDF/HDF
Laminate
Phenolic Composites
Plastic Acrylic & Plexiglas®
Sign Foam Sign Board & HDU
Solid Surface
Steel and Stainless Steel
Veneered Plywood
Wood
Xanita® Lightboard™ and X-Board™
Please see below for the full list of contents of this impressive kit:
Solid Carbide Single 'O' Flute Plastic Cutting 1/8 Dia x 1/2 x 1/4 Inch Shank
High Precision Steel Router Collet Reducer 1/4 Overall Dia x 1/8 Inner Dia x 1 Inch Long
High Precision Steel Router Collet Reducer 1/2 Overall Dia x 1/4 Inner Dia x 1 Inch Long
High Precision Steel Router Collet Reducer 1/2 Overall Dia x 3/8 Inner Dia x 1-3/16 Long
Solid Carbide Carving Liner 18 Deg x 1/4 Dia x 5/8 x 1/4 Inch Shank x 1-Flute
Solid Carbide CNC Foam Cutting Up-Cut Square End Spiral 1/8 Dia x 1-1/8 x 1/4 Shank x 2-1/2 Inch Long Router Bit
Solid Carbide CNC Foam Up-Cut Cutting Square End Spiral 1/4 Dia x 2-1/4 x 1/4 Shank x 2-1/2 Inch Long Router Bit
Solid Carbide Up-Cut Spiral Ball Nose 3/32 Radius x 3/16 Dia x 1/2 x 1/4 Shank x 2-1/2 Inch Long x 2 Flute Router Bit
Solid Carbide Up-Cut Spiral Ball Nose 1/8 Radius x 1/4 Dia x 1/2 x 1/4 Shank x 2-1/2 Inch Long x 2 Flute Router Bit
CNC Solid Carbide Spiral for Steel & Stainless Steel with AlTiN Coating 3-Flute x 1/8 Dia x 3/8 x 1/4 Shank x 1-1/2 Inch Long Up-Cut Router Bit / 45º Corner Chamfer End Mill
CNC Compression Solid Carbide ZrN Coated Honeycomb Cutting 3/8 Dia x 1-1/4 x 3/8 Shank x 6-Flute
CNC In-Groove Insert Engraving Tool Body 1/4 Inch Shank
CNC Solid Carbide ZrN Coated Honeycomb Cutting Hogger 1/4 Dia x 1-1/4 x 1/4 Shank x 4 Inch Long x 6-Flute
1/2 Inch Shank CNC Extension Adapter for 1/4 Inch Shank Router Bits
CNC Variable Helix Spiral Square Bottom 1/4 Dia x 5/8 x 1/4 Shank Solid Carbide AlTiN Coated End Mill
Solid Carbide CNC Spektraâ„¢ Extreme Tool Life Coated Spiral 'O' Flute, Plastic Cutting 1/8 Dia x 1/2 x 1/8 Shank Up-Cut Design Router Bit
Solid Carbide CNC Spektraâ„¢ Extreme Tool Life Coated Spiral 'O' Single Flute, Plastic Cutting 3/16 Dia x 5/8 x 1/4 Shank x 2 Inch Long Up-Cut Router Bit
Solid Carbide CNC Spektraâ„¢ Extreme Tool Life Coated Spiral 'O' Flute, Plastic Cutting 1/4 Dia x 3/4 x 1/4 Inch Shank Up-Cut Router Bit
CNC Insert V-Groove 45 Deg x 7/8 x 1/2 Inch Shank
Insert V-Groove 60 Deg x 1-1/16 Dia x 29/32 x 1/2 Inch Shank CNC
Insert V-Groove 90 Deg x 3/4 x 1/2 Inch Shank CNC
CNC Solid Carbide Spiral for Steel & Stainless Steel with AlTiN Coating 3-Flute x 1/4 Dia x 5/8 x 1/4 Shank x 2-3/8 Inch Long Up-Cut Router Bit / 45º Corner Chamfer End Mill
Solid Carbide Insert 30 Deg x 0.005 Inch V Tip Width Engraving Knife for In-Groove System
Carbide Tipped Double Edge Folding V-Groove 90 Deg x 0.090 Inch Tip Width x 1/2 Dia x 13/64 x 1/4 Inch Shank
Carbide Tipped Double Edge Folding V-Groove 108 Deg x 0.090 Inch Tip Width x 5/32 x 1/2 Dia. x 1/4 Inch Shank
CNC Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Compression Spiral 3/8 Dia x 1-1/4 Inch x 3/8 Shank
CNC Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Compression Spiral 1/2 Dia x 1-1/4 x 1/2 Inch Shank
CNC Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Compression Spiral 1/4 Dia x 7/8 x 1/4 Inch Shank
Solid Carbide CNC Spektraâ„¢ Extreme Tool Life Coated Spiral 'O' Flute, Plastic Cutting 1/8 Dia x 1/2 x 1/4 Shank Up-Cut Design Router Bit
Solid Carbide CNC Spektraâ„¢ Extreme Tool Life Coated Spiral 'O' Flute, Plastic Cutting 1/4 Dia x 1 x 1/4 Inch Shank Up-Cut Router Bit
Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Spiral Plunge 1/4 Dia x 3/4 x 1/4 Inch Shank Up-Cut
Solid Carbide V-Groove 60 Deg x 1/4 Dia x 7/32 x 1/4 Inch Shank
Solid Carbide Spiral Plunge with Corner Radius 1/16 Radius x 1/4 Dia x 3/4 x 1/4 Inch Shank Up-Cut
CNC 2D and 3D Carving 0.10 Deg Straight Angle Ball Tip 1/4 Dia x 1/8 Radius x 1-1/2 x 1/4 Shank x 3 Inch Long x 2 Flute Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Router Bit
CNC Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Compression Spiral 1/8 Dia x 13/16 Inch x 1/8 Shank
CNC 2D and 3D Carving 3.6 Deg Tapered Angle Ball Tip 1/8 Dia x 1/16 Radius x 1 x 1/4 Shank x 3 Inch Long x 3 Flute Solid Carbide Up-Cut Spiral Spektraâ„¢ Extreme Tool Life Coated Router Bit
Solid Carbide CNC Spektraâ„¢ Extreme Tool Life Coated Spiral 'O' Flute, Plastic Cutting 1/4 Dia x 3/4 x 1/4 Inch Shank Down-Cut Router Bit
CNC 2D and 3D Carving 6.2 Deg Tapered Angle Ball Tip x 1/32 Dia x 1/64 Radius x 1 x 1/4 Shank x 3 Inch Long x 3 Flute Solid Carbide Up-Cut Spiral Spektraâ„¢ Extreme Tool Life Coated Router Bit
CNC 2D and 3D Carving 5.4 Deg Tapered Angle Ball Tip 1/16 Dia x 1/32 Radius x 1 x 1/4 Shank x 3 Inch Long x 4 Flute Solid Carbide Up-Cut Spiral Spektraâ„¢ Extreme Tool Life Coated Router Bit
CNC 2D and 3D Carving 1 Deg Tapered Angle Ball Tip x 1/8 Dia x 1/16 Radius x 1-1/2 x 1/4 Shank x 3 Inch Long x 3 Flute Solid Carbide Up-Cut Spiral Spektraâ„¢ Extreme Tool Life Coated Router Bit
Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Up-Cut Ball Nose Spiral 1/8 Radius x 1/4 Dia x 1 Inch x 1/4 Shank Router Bit
Solid Carbide Spektraâ„¢ Extreme Tool Life Coated Up-Cut Ball Nose Spiral 1/4 Radius x 1/2 Dia x 1-1/4 Inch x 1/2 Shank Router Bit
CNC 2D and 3D Carving Flat Bottom 0.10 Deg Angle x 1/8 Dia x 1-3/32 x 1/4 Shank x 2-1/2 Inch Long x 4 Flute Solid Carbide Up-Cut Spiral Spektraâ„¢ Extreme Tool Life Coated Router Bit
Solid Carbide Up-Cut Spiral 1/4 Dia x 3/4 x 1/4 Shank x 2-1/2 Inch Long Composite, Fiberglass & Phenolic Cutting Spektraâ„¢ Extreme Tool Life Coated Router Bit
Solid Carbide CNC Spiral 'O' Flute, Aluminum Cutting 1/8 Dia x 5/16 x 1/8 Shank Up-Cut ZrN Coated Router Bit
Solid Carbide CNC Spiral 'O' Flute, Aluminum Cutting 1/8 Dia x 1/4 x 1/4 Shank Up-Cut ZrN Coated Router Bit
Solid Carbide CNC Spiral 'O' Flute, Aluminum Cutting 1/8 Dia x 1/2 x 1/4 Shank Up-Cut ZrN Coated Router Bit
Solid Carbide CNC Spiral 'O' Flute, Aluminum Cutting 3/16 Dia x 1/2 x 1/4 Shank Up-Cut ZrN Coated Router Bit
Solid Carbide CNC Spiral 'O' Flute, Aluminum Cutting 1/4 Dia x 5/8 x 1/4 Shank Up-Cut ZrN Coated Router Bit
Solid Carbide CNC Spiral 'O' Flute, Aluminum Cutting 1/4 Dia x 5/8 x 1/4 Shank Down-Cut ZrN Coated Router Bit
