Ambersil RTU Biodegradeable Water Based Degreaser
501551
From £17.18 £14.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Buy 3 for £15.47 £12.89 each
  • Buy 6 for £14.60 £12.17 each
  • Buy 15 for £13.75 £11.46 each
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
  • Non-flammable water based degreaser
  • Removes oil, grease, grime, silicone, wax, nicotine, soot, ink and coffee
  • Safe to use on most plastics, rubber and painted surfaces
  • Also helps to prevent flash rusting
  • Available as a 750ml ready to use trigger spray
A non-flammable water based degreaser from Ambersil that is an alternative to traditional solvents, whilst still exhibiting a high degree of solvency power. Suitable for use within industrial, automotive, engineering, transport, marine, electronic or aviation applications. Tough enough to remove oil, grease, grime, silicone, wax, nicotine, soot, ink and coffee but safe to use on most plastics, rubber and painted surfaces. Containing a highly effective corrosion inhibitor it will also help to prevent flash rusting. Use it by spraying, soaking, brushing, immersion, wiping or ultrasonic. Available as a 750ml ready to use trigger spray.
