Axcaliber 12 Piece 1/2" (12.7mm) Long Shank Cutter Set
666066
666066
- 12 piece set consists of:
- 3 x Two Flute Straight cutters 6.3, 12.7 & 19mm dia
- 1 x 6.3mm Radius Box cutter
- 1 x 12.7mm Template Profile cutter with bearing
- 1 x 45° Vee Groove cutter
- 1 x 12.7mm Radius Rounding Over cutter with bearing
- 1 x 12.7mm Radius Cove cutter with bearing
- 1 x 45° Chamfer cutter with bearing
- 1 x 9.5mm Rebate cutter with bearing
- 1 x 6.3mm Radius Roman Ogee cutter
- 1 x 12.7mm 14° Dovetail cutter
- Show More
Show more
Show less
1/2"(12.7mm) shank cutters are less susceptible to vibration or chatter making them a good choice if you have a router with a 1/2"(12.7mm) collet. The 48mm long shanks of these cutters are very useful for many other applications where reach of standard shank cutters is insufficient, for example router table use or when a sub base is in use.
Shank Diameter | 1/2" (12.7 mm) |
#AxminsterTools
