Axcaliber 45 degree Chamfer Cutter Head
702477
702477
- Hard aluminium alloy body with high resistance to tensile and yield stress
- 2 solid tungsten carbide Knives 50 x 12 x 1.5mm
- Suitable for manual feed
- Pins for the automatic positioning of the knives
Show more
Show less
Axcaliber Chamfer cutter heads cut clean, accurate bevels, chamfers and joints that are great for edge work. Cutting diameter 150mm, bore size 30mm.
EAN Barcode | 5052511038497 |
