Axcaliber Bead Ovolo Cutter
666151
From £23.38 £19.48
1 Review
  • Buy 3 for £22.21 £18.51 each
  • Buy 6 for £21.04 £17.53 each
  • Buy 10 for £19.87 £16.56 each
In Stock - Ready to dispatch
  • These cutters add a double bead to the moulding
  • Ideal for decorative edging, suitable for straight or curved work
  • Manufactured using the very latest technology
  • SAE4140 steel shank hardened to Rockwell 45 HRC
  • Diamond ground micrograin tungsten carbide tip
  • Virtual mirror finish ensures durable, clean cutter
  • Thick PTFE coating helps cutter to remain free of resin
  • 1/4" shank
Assurance with Axcaliber
- see how they're made
A variation on the standard ovolo cutter adding a double bead to the moulding. Suitable for straight or curved work as the bearing will guide the cutter around the edge of the workpiece.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
5.00 1
