Axcaliber Bevel Cutters
AX945548
AX945548
- Two-flute bevel cutters in 3 angles: 15°, 22.5° or 30°
- For applying a bevelled edge to thicker timbers
- Use for jointing, boxes, or multi-sided containers
- 15° bevel will produce a design with 12 sides
- 22.5° bevel 8 sides
- 30° bevel with 6 sides
- 22mm depth Cut
- 1/2" shank
- Supplied in storage case
Axminster Workshop Centrotec Compatible Depth Adjustable Bit HolderSpecial Price £3.98 £3.32 was £6.98 £5.82 Save £3.00 £2.50
Show more
Show less
A range of two-flute bevel cutters available in three different angles: 15°, 22.5° or 30°. For applying a bevelled edge to thicker timbers or used for jointing, boxes or multi-sided containers. A 15° bevel will produce a design with 12 sides, 22.5° bevel 8 sides and 30° bevel 6 sides. 1/2" shank. Supplied in storage cases.
Shank Diameter | 1/2" (12.7 mm) |
#AxminsterTools
