Axcaliber Bevel Panel Raising Cutter
666208
666208
- Produces an attractive 16° bevel on raised panel edges
- Bearing guided, suitable for use on curved head panels
- Maximum speed of 12,000 rpm
- Precision made on multi axis CNC machines
- PTFE coating helps cutter to remain free of resin
- 1/2" shank
- This cutter is for use in router tables only
Show more
Show less
A wide bevel style panel raising cutter for use only in a router table with a maximum speed of 12,000 rpm. The cutter is bearing guided and is suitable for use on curved head panels. Please note this cutter is for use in router tables only.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
D = Overall Diameter | 76 mm (3") |
EAN Barcode | 5052511030545 |
H = Horizontal Depth of Cut | 31.75 mm (1.1/4") |
Shank Diameter | 1/2" (12.7 mm) |
X = Depth of Cut | 16 mm (5/8") |
