Axcaliber Contract 254mm TCT Saw Blades
AX826565
AX826565
- Generously sized TCT tips brazed onto tensioned quality steel plates
- Rip 24T, Combination 40 or 50T, Fine Crosscut 80T
- 30mm bore, all blades
Show more
Show less
The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find a blade to suit every requirement. Bore size 30mm. A range of bore reducing bushes is available.
Blade Diameter | 254 mm |
Bore Size | 30 mm |
Maximum RPM | 7,600 rpm |
