Axcaliber Convex Multi-Bead Cutter
666183
666183
- Create an attractive triple bead edging
- Bearing guide for use on curved work
- Decorative edges on table tops and shelving
- Precision made on multi axis CNC machines
- PTFE coating helps cutter to remain free of resin
- 1/4" shank
- 3.2mm radius
Axcaliber Router Cutter Bearing - D=15.88 - X=6.35mmSpecial Price £1.34 £1.12 was £4.48 £3.73 Save £3.14 £2.62
Show more
Show less
This cutter produces a very attractive triple beaded edge in one simple pass. Used with either the fence or without (self-guided). Stopping the moulding short creates a classic looking edge on shelving.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up. 3.2mm radius.
D = Overall Diameter | 22.2 mm (7/8") |
EAN Barcode | 5052511030316 |
R = Radius | 3.2 mm (1/8") |
X = Depth of Cut | 25.4 mm (1") |
