Axcaliber Edge Beading Router Cutters - 1/4" Shank
AX803746
AX803746
- Manufactured using the very latest technology
- SAE4140 steel shank hardened to Rockwell 45 HRC
- Diamond ground micrograin tungsten carbide tip
- Virtual mirror finish ensures durable, clean cutter
- PTFE coating helps cutter to remain free of resin
- 1/4" shank
Show more
Show less
Produced using advanced technology on up-to-the-minute multi axis CNC machinery. Shanks made from SAE4140 steel hardened to Rockwell 45 HRC, renowned for its hardness and strength, and the tips are made from diamond ground micrograin tungsten carbide. A virtual mirror finish ensures a durable, clean cutter capable of holding a sharp edge and a thick PTFE coating minimises resin build-up. All cutters are produced with high shearing angles.
#AxminsterTools
