Axcaliber Extended Shank Beading Cutter
952559
952559
- Axcaliber long shank beading cutter
- 1/4"(6.35mm) bead with a chamfer at each side
- PTFE coating helps cutter to remain free of resin
- 1/2" shank
Show more
Show less
The addition of decorative beads can add interest to your furniture projects but it is not easy to apply a bead set in from the edge of a rail using a router. The traditional method was by using a scratch stock, but by using this cutter and a router you will tackle the job faster with consistent results. With a 1/2" shank 76mm long this beading cutter will allow you to position your beads inset from the rail edge producing some attractive design options. Also useful for producing tongue and groove boarding with a vee groove.
D = Overall Diameter | 22.2 mm (7/8") |
EAN Barcode | 5052511054022 |
R = Radius | 3.2 mm (1/8") |
Shank Diameter | 1/2" (12.7 mm) |
X = Depth of Cut | 16 mm (5/8") |
