Axcaliber Finger Joint Cutter
- Produces an incredibly strong joint with large gluing area
- Join boards end to end or edge to edge
- SAE4140 steel shank hardened to Rockwell 45 HRC
- Diamond ground micrograin tungsten carbide tip
- Virtual mirror finish ensures durable, clean cutter
- PTFE coating helps cutter to remain free of resin
- 1/2" shank
- This cutter is for use in router tables only
Trend Tool and Bit Cleaner - 532mlSpecial Price £14.78 £12.32 was £16.78 £13.98 Save £2.00 £1.67
The extra gluing area produced by using this cutter makes for an incredibly strong edge to edge joint. With a maximum cutting depth of up to 38mm, most board thicknesses can be accommodated. Recommended for router table use only.
D = Overall Diameter | 35 mm |
EAN Barcode | 5052511030682 |
Shank Diameter | 1/2" (12.7 mm) |
X = Depth of Cut | 38 mm (1.1/2") |
