Axcaliber Kitchen Worktop Cutter
AX1034264
AX1034264
- Great value TCT worktop cutter, 51mm depth of cut
- For use with kitchen worktop jig and 1/2" router
- Clean finish in laminate and solid wood worktops
Blum CLIP-TOP 110 deg. Soft Close Hinge & Mount Plate With ScrewsFrom £5.78 £4.82
Show more
Show less
A great value cutter for a one off job or those times when it may not be a good idea to use your best high quality expensive cutter. This 1/2" TCT router cutter will cut solid wood and laminate kitchen worktops, leaving a clean finish for a close fitting joint, when used with a worktop jig and 1/2" router. Twin flutes ensure smooth and efficient cutting. With a cutting depth of 51mm it is ideal for general worktop cuts.
N.B. The cutter does not have a bottom cut.
D = Overall Diameter | 12.7 mm (1/2") |
Shank Diameter | 1/2" (12.7 mm) |
X = Depth of Cut | 51 mm (2") |
