Axcaliber Euro Blank Limiters
AX20841
AX20841
- 40mm or 50mm wide, 32.5mm or 34mm deep
- Supplied for customers to grind their own profiles
- Match the Euro Blank Cutters
Show more
Show less
These blank limiters, either 40mm or 50mm wide, can be supplied for customers to grind their own profiles. Distance from centre of mounting hole to end of the blade is 32.5mm for the 40mm wide knife and 34mm for the 50mm.
