Axcaliber Profile Knives and Limiters-00
AX20671
AX20671
- Fits the CMT, Whitehill and other small moulding blocks currently available
Show more
Show less
Euro cutter which will fit the CMT, Whitehill and many of the small moulding blocks currently available, either with or without limiters. The locating pins are 6mm diameter and are spaced 24mm apart. This cutter can also be used for manufacturing small mouldings with the Axminster Universal Block, shown elsewhere in this section.
