Axcaliber Three Wing Slot Cutter Set
952565
From £71.28 £59.40
7 Reviews
  • Buy 3 for £67.72 £56.43 each
  • Buy 6 for £64.15 £53.46 each
  • Buy 10 for £60.59 £50.49 each
In Stock - Ready to dispatch
  • Axcaliber three wing slot cutter set (1/2" shank)
  • A very versatile set for a wide range of groove sizes
  • Suitable for grooves from 3.2mm to 18mm x 12.7mm deep
  • PTFE coating helps minimise resin build-up
  • This cutter is for use in router tables only
Assurance with Axcaliber
- see how they're made
Designed for router table use, this set can be used to create slots, grooves and rebates from 3.2mm to 18mm in depth. The set includes: 4 x three winged cutters 3.2, 4, 4.8, and 6.4mm in width. 1/2" shank arbor. 21 shims (8 x 0.1mm, 4 x 0.5mm, 5 x 1mm, 2 x 3mm and 2 x 6mm).
N.B. The carbide edges of the cutters should never touch; arrange the cutters to prevent this. Use only the thicknesses provided in the set. Be sure all cutters are assembled in the correct rotational direction.Safety tips: Never use the slot cutter set without shims between the cutters. The distance between the cutters can vary from 1mm to 1.5mm. A shim must also be positioned between the ball bearing and the cutters.
4.90 7
