Axminster Workshop Pocket Vernier Caliper - 100mm
519001
519001
- Pocket-sized
- Movable head locks for comparative measurement
- Easy-to-read non-reflective 100mm scale calibrated to 0.05mm resolution
- External, internal, depth and distance from an edge measurement
- Supplied with leatherette case
Show more
Show less
A top-pocket-sized vernier for the accuracy-conscious woodworker or craftworker. The movable head locks for comparative measurement using a small thumbscrew. The easy-to-read non-reflective 100mm scale is calibrated to a resolution of 0.05mm. The four functions include external, internal, depth and distance from an edge measurement. The caliper comes with a leatherette case.
EAN Barcode | 5052511024612 |
Measuring Range | 0 mm to 100 mm |
