Axminster Workshop 13mm Keyed Chuck - B16
- Good quality keyed chuck, B16 arbor fitting
- Jaw opening range is 1mm to13mm
- Suitable for use in pillar drills and lathes
- A choice of arbors available separately
A good general purpose drill chuck with no arbor, suitable for use in pillar drills and lathes. The jaws close right down to almost nothing for use with very small drill bits. Jaw opening range is 1-13mm, chuck key included. Machined with a B16 arbor fitting. Available with a choice of Morse Taper 1, 2 or 3 arbors separately.
EAN Barcode | 5052511038114 |
