Axminster Engineer Series 13mm Super Precision Drill Chuck
- For high accuracy drilling
- Excellent run out and torque transmission characteristics
- Close tolerance key fit
- Super precision ground J6 taper
- Ground arbors available seperately
Superb precision chuck with excellent run out of 0.15mm maximum and outstanding torque transmission characteristics. For use in pillar drills, mills or lathes. Well presented, with close fitting key and precision ground tapers. A firm favourite with our own servicing and production workshops. Suitable ground arbors are available separately. Takes drill bits from 1-13mm. The 13mm chuck has a J6 taper.
EAN Barcode | 5052511022427 |
