Axminster Workshop 16mm Keyless Chuck
- Rugged, all steel drill chucks, all with B16 mounting tapers
- Suitable for use in drill presses, milling machines or all types of lathes
- Jaw opening range is 3-16mm
- Chucks fit the optional B16- 1, 2 or 3MT arbors listed separately
High precision, rugged, all steel drill chucks with B16 mounting tapers. Equally suitable for use in drill presses, milling machines or all types of lathes. The jaw opening range is 3-16mm. This chuck fits the optional B16- 1, 2 or 3MT arbors listed separately. A chuck to upgrade the standard chucks offered on some machines, or as accessories for wood or metal turning lathes.
EAN Barcode | 5052511038107 |
