Axminster Engineer Series AP0 Arbor Press
- Hand operated; applies firm and uniform pressure
- Useful for assembling brass tubes into wooden pen blanks
- 114mm travel;19mm square arbor; 0.5 Tonne rating
Hand operated arbor press which is very useful for assembling the brass tubes into the wooden blanks of the woodturning project kits. But, these have many other uses, such as rivetting, pressing eyelets, installing or removing bearings, etc. Punches, inserters, or other tools/dies may be added to the end of the ram depending on the desired task. Pressure is firm and uniform and the components are held square whilst being inserted. It has a travel of 114mm and a 19mm square arbor. 0.5 Tonne.
Arbor Size | 19 mm |
Base Size | 241 mm x 102 mm |
EAN Barcode | 5052511012398 |
Max Stroke | 114 mm |
Model | AP0 |
Nett Weight | 8.5 kg |
Overall Height | 250 mm |
