Axminster Workshop Brown Polishing Compound
- Brown; commonly known as Tripoli
- First stage on non-ferrous metals, copper, brass
- Use on a stitched or loose-leaf mop
- Cut 7; Colour 7
- Bar size 100 x 35 x 20mm; weight 100g
Axminster Workshop Red Polishing CompoundSpecial Price £2.95 £2.46 was £3.68 £3.07 Save £0.73 £0.61
Axminster Workshop Yellow Polishing CompoundSpecial Price £2.38 £1.98 was £2.98 £2.48 Save £0.60 £0.50
Axminster Workshop Green Polishing CompoundSpecial Price £2.38 £1.98 was £2.98 £2.48 Save £0.60 £0.50
Axminster Workshop Blue Polishing CompoundSpecial Price £2.38 £1.98 was £2.98 £2.48 Save £0.60 £0.50
Axminster Professional Final Finish Buffing PowderSpecial Price £5.42 £4.52 was £6.78 £5.65 Save £1.36 £1.13
Brown compound: commonly known as Tripoli and used in the first stage on non-ferrous metals, copper, brass etc. Its use on a stitched or loose-leaf mop depends on the piece’s initial condition. It removes minor imperfections, blemishes and small scratches.
Our compound bars are colour coded, making them immediately identifiable. Each one is a combination of a selected abrasive in a specific binder. Each colour has two reference numbers. The first denotes the 'Cut' or level of abrasiveness; the higher the number, the coarser the grit. The second number is the 'Colour’, this relates to sheen; the higher the number, the shinier and glossier the result.
Brown: Cut 7; Colour 7.
Bar size 100 x 35 x 20mm; weight 100g.
EAN Barcode | 5052511116317 |
