Axminster Workshop Engineers Squares
AX23310
AX23310
- General duty steel squares
- Hardened steel blades
- Intended for sheet metal use but also popular with cabinet makers
- Holds its accuracy over a long period of time
- Accurate on both inside and outside edges
Show more
Show less
These general duty steel squares have hardened steel blades securely riveted onto a steel stock. Although intended primarily for sheet metal work use they are also very popular with cabinet makers who have a need for a square which will hold its accuracy over a long period of time. Unlike conventional joiner's squares they are accurate on both the inside and outside edges. Their realistic price and good level of accuracy make them exceptional value for money.
